1999 Chevy Malibu Sluggish Startup
MANZANO16
  • 1999 CHEVROLET MALIBU
  • 6 CYL
  • 115,000 MILES
My car was very sluggish to start up/turn over this morning, but drove fine to work. Once I got here I tried to turn the car on again, and it barely turned over, then died. I'm able to get the car on and keep it on when hitting the accelerator, just concerned this is going to get much worse quickly. If someone could point me in the right direction for a quick fix I'd greatly appreciate it!
Tuesday, August 26th, 2008 AT 6:47 AM
2CARPRO JACK
  • 11,533 POSTS
So it turns over, just slow like a low battery? Or it turns over and wont hold idle, and tries to die? If it wont idle check for vacuum leaks first, could be a bad Idle Air Control valve
Tuesday, August 26th, 2008 AT 7:44 AM
MANZANO16
  • 6 POSTS
This morning (the second time) it did turn over but quickly died. It does feel like a battery, though, so I'll try that first. But I did replace the battery less than 2 years ago. Thanks for the tip on the vacuum, I'll give that a try also.
Tuesday, August 26th, 2008 AT 7:48 AM
DOCFIXIT
  • 18,828 POSTS
So what happened when you left work? If it cranked slow again and didnot idle well starter drag could be the problem. If starter draws to many amps then when you get it running system voltage is low and PCM does not function well. Have a starter draw test done. An Auto Zone can do this free.
Friday, August 29th, 2008 AT 7:04 PM
BADBO
  • 35 POSTS
Please do check the alternator to see if the output is correct.
Badbo
Friday, August 29th, 2008 AT 7:32 PM
