1996 Chevy Malibu lumina randomly won't start
HERBERTWEST
1996 Chevy Malibu 149xxx miles
occasionally if after driving for a while if i try to start my car it will start, but it will sputter out in a few seconds and then won't start until like an hour after. [i deliver pizzas so my car tends to be on and off frequently while i'm working.]
any ideas what the problem might be? i'll post any other information that might be needed. i was told it might be the fuel pump.
Feb 11, 2009 at 2:58 PM
  • 75,988 POSTS
Could be but you need to check the fuel pressure to confirm it-also the ignition switch
Feb 11, 2009 at 3:11 PM
HERBERTWEST
[quote:1e33f9dcff="rasmataz"]i was told it might be the fuel pump.
Could be but you need to check the fuel pressure to confirm it-also the ignition switch[/quote:1e33f9dcff]
if i try to start the car it tries to turn over, but it acts like there isn't any gas in it. this happened yesterday and i had at least 3/4 of a tank.
Feb 12, 2009 at 2:08 AM
  • 75,988 POSTS
Do below and tell me what happened
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 12, 2009 at 7:03 AM
