THE REASON THE FANS ARE NOT COMING ON IS THAT THE FAN RELAY IS BAD OR THE TEMP COOLANT SWITCH IS NOT WORKING. AS FOR THE WHITE SMOKE OUT THE TAIL PIPE. WHITE MEANS WATER, BLUE MEANS OIL AND BLACK MEANS FUEL. YOU HAVE PROBABLY HAVE A SLIGHT BLOWN HEAD GASKET. IF WHEN YOU GET THE FANS TO WORK AND THERE IS NOT TOO MUCH WHITE SMOKE COMING OUT, YOU CAN TRY SOME BLOCK SEAL TO TEMP FIX THE PROBLEM, BUT GET GOOD STUFF AND FOLLOW THE INSTRUCTIONS.
SPONSORED LINKS
Thursday, August 9th, 2007 AT 2:36 PM
