1990 Chevy Lumina fuel system
CHLTME
  • 1990 CHEVROLET LUMINA
  • 6 CYL
  • 150,000 MILES
Hi, I am having an issue with not getting enough fuel. I think it may be the fuel filter. Car starts but keeps stalling and unable to drive very far. Also white smoke coming out of the exhaust. I just bought it to get back and forth to finding a job and unable to spend much money on repairs. Thank you for your time.
Monday, November 2nd, 2009 AT 12:56 PM
Hi chltme and TY for the donation
also white smoke coming out of the exhaust. This one here could be a blown headgasket cracked head or block/intake manifold leak- coolant is leaking into the cylinders diluting the mixture which is unburnable causing it to stall and the white smoke -could very be a clogged-up fuel filter or a weak fuel pump. Check the fuel pressure to rule both of them out-
Monday, November 2nd, 2009 AT 1:28 PM
CHLTME
Hi again, I don't know anything about cars. Just trying to make it run in the least expensive way I can. Is there any way I can find a diagram of the engine so I may be able to try and change the fuel filter. Older woman here just trying to find a job and get back and forth to it. No money to spare thanks again
Monday, November 2nd, 2009 AT 1:45 PM
