Chevrolet Lumina Flickering Lights
WHEEZER
My headlights and interior lights flicker like a strobe light. I replaced the alternator 10 months ago and the flickering would be random, now it is all the time. Could it be the alternator?
Oct 17, 2007 at 3:59 PM
  • 75,988 POSTS
Check the battery and alternator connections-if okay get the charging system check.
Oct 17, 2007 at 10:52 PM
WHEEZER
[quote:04b5f4b0c8="rasmataz"]Check the battery and alternator connections-if okay get the charging system check.[/quote:04b5f4b0c8] thank you for the advice i will check it out
Oct 19, 2007 at 4:05 AM
Suggested Repair
Check the battery and alternator connections. If they are secure and in good condition, have the charging system tested.
Conversation Summary
The owner of a Chevrolet Lumina reports headlights and interior lights flickering like a strobe light. The problem was intermittent after an alternator replacement 10 months earlier but is now constant. The expert advises checking the battery and alternator connections and, if those are okay, having the charging system tested. The owner plans to follow that advice.
