1995 Chevy Lumina Tail Lights Out
CHEVROLET
FREZZELLREESE
My daughter's 1995 Chevy Lumina LS, 134,000 miles seems to have a problem with the rear night-time lights. The rear brake lights work and so does the signals. But no lights in the back at night. Also, the dashboard lights are out. Are these connected and what could be the problem?
Dec 17, 2006 at 12:53 PM
2CARPRO JACK
  • 11,533 POSTS
Start by checking all the fuses and bulbs(not dash lights). Its possible a bulb shorted in the running lights causing the fuse to blow.If thats not it then the headlight switch could be the culprit.Test for dash light powqer and tail light power at the back of the switch when turned on
Dec 18, 2006 at 3:26 AM
Suggested Repair
Check the fuses and running-light bulbs first; a shorted bulb can blow the fuse. If those are good, test the headlight switch for dash-light and tail-light power when the switch is on.
Conversation Summary
The owner of a 1995 Chevy Lumina reports that the rear night running lights and dashboard lights are out, while the brake lights and turn signals still work. The expert advises checking the fuses and bulbs, noting that a shorted running-light bulb may have blown a fuse, and testing power at the headlight switch if that is not the cause.
