2001 Chevy Silverado No Parking Lights
CHEVROLET
Q8_Z71
Chevy Silverado 2001-[u:8271d62ccd] No Front Parking Lights Or Drl's[/u:8271d62ccd]
Any ideas why this would be or what to check, pretty sure I found and checked any fuse that could cause it.
Blinkers work, just no parking lamps or drl's.
Thanks in advance.
Jul 15, 2006 at 8:55 AM
MIKEYBDMAN
  • 623 POSTS
[quote:510e0d4e72="q8_z71"]Chevy Silverado 2001-[u:510e0d4e72] No Front Parking Lights Or Drl's[/u:510e0d4e72]
Thanks in advance.[/quote:510e0d4e72]
Ok, I see two things that tie in to each system. First is the G100 ground. There should be a small wire that comes out of the forward lamp harness on the left front body mount. This wire grounds to the same stud as the negative battery cable. I would check that ground and wire for loosness, corrosion and breaks.
The other is the Body Control Module. But that seems rather odd that it would effect both items.
Jul 15, 2006 at 9:41 AM
Q8_Z71
Thanks bud.. will check n let ya know!
:D
Jul 15, 2006 at 9:58 AM
Suggested Repair
Check the G100 ground and the small wire from the forward lamp harness at the left front body mount, which shares the negative battery cable stud. Inspect it for looseness, corrosion, and breaks. A Body Control Module fault is possible but less likely.
Conversation Summary
A 2001 Chevy Silverado owner reported no front parking lights or DRLs while the blinkers still worked and the related fuses appeared good. The expert advised checking the G100 ground wire at the left front body mount for looseness, corrosion, or breaks, and noted the Body Control Module as a less likely shared cause.
