1993 Chevrolet Lumina Idle Stall Brake Booster Fix
1993 ALL OTHER MAKES ALL OTHER MODELS
GRIMMY523
While the brakeis depressed at idle speeds the car wants to stop and sometimes does also sometimes when you accelerate after a stop it boggs down. I have replaced the plugs and wires. The rpm gauge also fluctuates when at idle with the brake depressed.
Apr 16, 2006 at 11:37 AM
LOSONE
  • 1,616 POSTS
Simple, you have a bad brake booster that is leaking vacuum when you depress the pedal causing all sorts of wierd problems. Good Luck
Apr 16, 2006 at 11:41 AM
GRIMMY523
How can it be a bad brake booster when the rpm fluctuates even when i n park.
Apr 17, 2006 at 10:09 AM
LOSONE
  • 1,616 POSTS
A vacuum leak is a vacuum leak regardless. It is greater when you depress the brakes. In the past 40 odd years of garage ownership I have replaced hundreds of brake boosters. Good luck
Apr 17, 2006 at 10:36 AM
Suggested Repair
Replace the brake booster. A booster that leaks vacuum when the pedal is pressed can cause idle stalling, bogging after a stop, and fluctuating RPM.
Conversation Summary
A 1993 Lumina stalls or wants to die at idle with the brake depressed, sometimes bogs when accelerating after a stop, and the RPM fluctuates. Plugs and wires were already replaced. The owner noted the RPM also fluctuates in park. The expert said a failing brake booster leaks vacuum, especially when the pedal is depressed, and recommended replacing the booster.
