1992 Chevrolet Lumina Dies in Drive
RAYNAE BAKKER
I have a 1992 Chevy Lumina 114,000 miles. This is becoming a more frequent problem, and is confusing because when it happens I get no warning lights, ie "check oil" "check engine". There's always plenty of gas in the car. When I'm driving, I'm fine for about 20 minutes or so, highway or stop and go, then say I'm driving 60 mph and I start to slow down, the car will start chugging a bit, and as I stop like at a stoplight, it will rev up and chug, and then die on me. It doesn't happen all the time, and I noticed it happens more when the outside temperature is above 40 degrees. Lately, its been happening sooner that 20 minutes later of driving. It will start right back up, but as soon as I put it in drive, it will die. If I put it in neutral at the stoplight it will idle fine, then when I put it back in drive it will die. Sometimes I have to start it three or four times before I can cross the intersection. The car drives fine otherwise. I don't want to be taken advantage of by a mechanic who realizes I don't have a clue what's going on. Please help!
Mar 13, 2006 at 5:01 AM
MVANNESSJR
  • 223 POSTS
Replace Torque Convertor Clutch Solenoid and the problem will magically vanish. Very problematic and popular problem on these boards but shop owners look at this last after they are done replacing half of your engine/transmission.
Mar 13, 2006 at 9:59 AM
Suggested Repair
Replace the torque converter clutch solenoid.
Conversation Summary
The owner of a 1992 Chevrolet Lumina with 114,000 miles reports that after about 20 minutes of driving the vehicle begins chugging, revs, and dies at stops, with no warning lights and plenty of fuel. It restarts and idles in neutral but dies when shifted into drive, sometimes requiring several restarts, and the problem is more common above 40 degrees and is occurring sooner. An expert recommends replacing the torque converter clutch solenoid, describing it as a common and often overlooked cause on these vehicles.
