1999 Chevy Lumina Temp Gauge Low
CHEVROLET
SONNYBOY
I have a 1999 Chevy Lumina 3.8 V6 engine with 145000 miles.When I start the engine and the car warms up the coolant temperature gauge reading hardly changes. What could be the cause?
Jan 10, 2007 at 1:06 AM
SERVICE WRITER
  • 9,123 POSTS
How is your heat?
Are you sure about a 3.8?
Jan 10, 2007 at 8:39 AM
SERVICE WRITER
  • 9,123 POSTS
You said:
You asked if the heater was putting out any hot air.Well it take awhile for it to get hot.the other day I started the car and it ran for about 5 or 10 minute before I drove off. I drove about 5 miles before the heat coming out was hot but the temp gauge was still on 100 or a little over. I stopped in a parking lot and let it idle for a couple of minutes and the needle went to the normal temp but, it doesn't stay up there.The out side temperature was 45 or 50 degrees
Jan 13, 2007 at 10:21 AM
SERVICE WRITER
  • 9,123 POSTS
Try a theromstat, sounds like it's stuck open.
Jan 13, 2007 at 10:23 AM
Suggested Repair
Replace the thermostat; a thermostat stuck open can keep the coolant temperature low and delay heater output.
Conversation Summary
The owner of a 1999 Chevy Lumina 3.8 V6 with 145,000 miles reports the coolant temperature gauge barely rises after warmup. Heat is slow to become hot, and the gauge stays near 100 until a short idle, then does not remain at normal. The expert recommends trying a thermostat because it sounds stuck open.
