1998 Chevrolet Lumina No Air From Vents
FPANTHER
please help, i just turn on my a/c today and it didnt work . i hear the motors turn on but no air blows in the car. please help its hot in south florida -
p.s. i just had the engine worked on they replace all the gaskets, head gaskets ,manifold gaskets ,valve cover , do you think they didnt plug something in or a belt is slipping please help asap.
ty fpanther, 1998 chevy lumina 3.1
Feb 25, 2007 at 5:41 AM
CHEVY22
  • 1,375 POSTS
ok so the blower motor comes on when you change the fan speed from high to low ???
Feb 25, 2007 at 5:50 AM
FPANTHER
yes the blower motor turns on its like the vents are closed no air comming inside
Feb 25, 2007 at 5:51 AM
CHEVY22
  • 1,375 POSTS
before we have you crawling all around the car chasing this problem you may want to consult the shop since they did just work on it , and if not we wil tackle it, this may be as simple a a vacuum line off of the engine , this would not allow the blen doors to open or close but there are several other things it could be , i would start there since there was major reair under the hood but consider taking it back
Feb 25, 2007 at 5:57 AM
FPANTHER
ty for all your help
Feb 25, 2007 at 6:09 AM
CHEVY22
  • 1,375 POSTS
no problem good luck with the shop and let me knwo how it works out
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 6:25 AM
Suggested Repair
Return the car to the shop that just did the engine gasket work. A disconnected vacuum line under the hood can keep the blend doors from opening, so the blower runs but no air reaches the vents. Have them check vacuum lines and HVAC door operation.
Conversation Summary
The owner of a 1998 Chevrolet Lumina says the blower motor runs when fan speed is changed, but no air comes from the vents, as if they are closed. This started after recent engine gasket work. The expert recommends taking it back to the shop and checking for a disconnected vacuum line that could prevent the blend doors from opening or closing.
