1995 Chevy Lumina Fan Runs Constantly
There are two or three fan relays. and all the same. Change them around and see if the symptom moves with the relay if not do as suggested below.
The sensor is located directly under the air intake to the throttle body. It has two wires one is yellow and the other color varies. Make sure the engine is cold and the radiator cap off. You will loose a little coolant and have a skinned knuckle or so as the space is tight..
It is cheaper to replace than an ECM as that may be the trouble but the last resort as the ECM's are pretty much bullet proof. The fans are controled by the onboard prom depending if the vehicle has A/C or not. If the sensor doesn't fix the problem it could be the prom.
Some 95's have replacable proms and some don't. If you computer is in the engine compartment then it can't be replaced but it can be reprogramed by a dealer. If the ECM is inside the car then the prom can be replaced and is a dealer item. Good luck Let me know
Suggested Repair
Suspect the coolant temperature sensor first, since the ECM uses it to command the driver's-side coolant fan; it is under the throttle-body air intake and has two wires, one yellow. With the engine cold and radiator cap off, replace the sensor if needed. Also swap the identical fan relays to see whether the constant running follows a relay. Treat the ECM or PROM as a last resort; some 1995 computers can have the PROM replaced or reprogrammed by a dealer depending on ECM location.
Conversation Summary
The owner of a 1995 Chevy Lumina with a 3.1 engine found the driver's-side fan running all night and pulled its underhood fuse. The expert said the left fan is the coolant fan and the right fan serves the condenser. The likely cause is the coolant temperature sensor feeding the ECM, though a fan relay is also possible. The expert advised swapping relays, replacing the sensor under the throttle-body intake, and considering the PROM or ECM only if that does not fix it.
