1997 Lumina A/C Blowing Fuses
1997 ALL OTHER MAKES ALL OTHER MODELS
DSCOTTNOEL
[b:b7bcd8fee0]Recently my 1997 Lumina started blowing the 10 Amp fuse that triggers the A/C relay to turn on the compressor. I have noticed that when I replace the fuse, the a/c works great until I turn off the switch, then when I turn the switch back on, the fuse pops. Without changing all of the components, what to you think could be the problem? I really appreciate your help.
Hot in Lexington,
Scott Noel[/b:b7bcd8fee0]
May 11, 2006 at 2:36 AM
LOSONE
  • 1,616 POSTS
It is either the compressor or the relay but 90% of the time it's the compressor. It is just at the point of getting ready to have a clutch failure. You can't replace the clutch just the entire compressor. Good luck
May 11, 2006 at 3:20 AM
