2001 Chevy Lumina Won't do nothing when trying to start
TJESI
  • 2001 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 234,000 MILES
Put the key in turn on all lights come on turn key to start nothing at all. Take key in and out of switch servel times and wait 5 mins to 10 mins then put key in and it starts right up? Only does this once every month maybe 6 months before it does it again bought a new key but no good.
Sunday, October 25th, 2009 AT 6:53 PM
BMRFIXIT
  • 19,053 POSTS
Very common for it to be a faulty ignition switch
next time it happens be prepared and check for power at the S terminal at the starter solenoid
its the small wire as a helper holding ignition in start position for you to start
if no power suspect and check ignition switch if have power suspect flat spot on the starter and a bad starter
good luck " �
Sunday, October 25th, 2009 AT 7:15 PM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
