2001 Chevy Lumina no start
BLENDO
Electrical problem
2001 Chevy Lumina 6 cyl Front Wheel Drive Automatic 78k miles
My 2001 lumina has been to the dealer 7 times for a no start situation, I turn the key and nothing happens no noise etc. It has been towed twice but it will usually start after repeated tries. They have fixed ground wires, replaced the battery. replaced the ignition cylainder twice,and today they are replacing the starter. Last week when it didn't start it showed security on the dash and they changed the ignition(key) cylainder. The keys have also been replaced twice. They also said the wiring was checked. Any ideas?
thanks
Nov 13, 2009 at 3:40 AM
  • 110,248 POSTS
Did they replace the ignition switch or the tumbler? Also, is the security light still coming on?
Nov 15, 2009 at 11:25 PM
BLENDO
ignition cylainder replaced and 2 new keys cut last week which had been done 2 years before. To be on the safe side I had the starter replaced as well, as they(dealer) said if the problem persisted that would be the remedy. would you agree?
thanks
Nov 16, 2009 at 3:52 AM
