Car will not start after bypassing key with a four OHM resistor
160,000 MILES • FWD • AUTOMATIC
SCOTT JENKINS2
First I had the blinking security light so I bypassed the pass key with a four ohm resistor. Security stopped flashing, but still no start. Next I did the re-boot protocol where I try to start, leave in run position for ten minutes three times, but still no start. Any suggestions on next step?
Dec 15, 2016 at 12:50 AM
HMAC300
  • 48,601 POSTS
take the resistor out and try it if that does not work it will need to be scanned for codes by a mechanic to see what is wrong with system.
Dec 15, 2016 at 1:47 AM
STEVE W.
  • 15,413 POSTS
What did the resistance in the original key read? Four ohms does not match any of the passkey values. They start much higher. Wrong resistor will prevent it from starting.
Dec 15, 2016 at 2:02 AM
SCOTT JENKINS2
It did clear the flashing security light so that should mean I got it right? Digital meter read 7.3 but analogread four ohms.
Dec 15, 2016 at 2:06 AM
STEVE W.
  • 15,413 POSTS
Neither of those are valid numbers for the system either. On 01 to 03 GMs there are 14 values from 523 ohms up to 11,800 ohms. You have to be within 3% of the correct number for it to work.
What was the reason you started using the resistors for? If it was a no start/security light with a known correct key it could be a problem anywhere from the contacts in the switch to the ECM.
If you have a low battery it can also cause problems because the system looks for a certain voltage drop across the key, low battery = wrong voltage.
Dec 15, 2016 at 8:43 AM
