First, there should be a security light that comes on when you turn the key to the run position before starting. If it stays on when you turn the key to the start position, if it flashes or stays on solid, the security system is stoping the car from starting. The bad part about that is a dealer is the only place that will have the proper test equipment for that type of problem.
One good thing I can tell you is this. If the security system is stopping the engine from starting, you shouldn't have spark or fuel to the engine. Since it starts with starting fluid, my guess is there is a problem with the injectors or the fuel pump isn't producing enough pressure.
THerefore, I need you to check two things. First, I need to know if you are getting enough pressure to the fuel rail. Here is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Next, if the pressure is good, we need to check for an injector pulse at each injector. Basically, it is a small test light that is used to detect power to the injector itself.
Overall, you will need a fuel pressure gauge and a noid light to complete these test. Most nationally recognized parts stores will lend or rent the tools needed. Go through the tests and let me know what you find.
SPONSORED LINKS
Saturday, December 5th, 2009 AT 8:46 PM
