1970 Impala, 350
1970 CHEVROLET IMPALA
JACKK09
I just had Flowmaster 40's put on my 70 and the hanger came loose for the exhaust and the exhaust banged around a good bit. I took it back and they repaired that and said I was good to go. I told them that since that happened, I had been hearing a leak out of the engine where the headers bolt on, they checked and said the gasket needed to be replaced but that the hanger coming off and exhaust banigng around would not cause the gasket to have an issue. This engine was just rebuilt, its a new gasket, could the issue be from the hanger not being correctly attached and it banging around for a day or two? THANKS
Apr 9, 2007 at 7:20 AM
MIKE H R
  • 3,094 POSTS
where the headers go on the engine is stronger than the exaust, i do not believe that the exaust hanger would make the gasket leak. check the bolts connecting the header to the engine and see if they are the right torque.
Apr 9, 2007 at 7:50 AM
