2000 corvette oil pressure
COTA252
i have a 2000 corvette with 69k mi 6 sp the oil pressure runs between 35 and 40 lbs this is my first vette is this normal . it is allso leaking coolant where the overflow hose connects under the radiator cap an has a miss at idle please help
Dec 29, 2006 at 7:55 AM
CHEVY22
  • 1,375 POSTS
hi
the oil pressure sounds normal , as far as the leak , have a cooling system pressure test done , it sounds like the rad neck is cracked , as far as the miss unless the ses light is on you probably dont have one , if you did the pcm would pick it up and set a code , but it may need a maint tune up plugs wires , this is very labor intensive though about 6 hrs but anyway have the pressure test done and the oil pressure is fine
take care
jim
Feb 17, 2007 at 7:22 AM
CORYFOSTVEDT
A tune up on a 99 vette is very simple anyone with a spark plug socket 3/8 ratchet and a 1" extension can do it. Oil pressure is good.
Apr 4, 2007 at 2:49 PM
