Oil Pressure Gauge maxed out
CHEVROLET
JGUMP
I have a 1997 Chevy Corvette, with the LS1 V8, 5.66L, 345hp engine. It has 117,000 miles on it and has been well maintained. Two days ago, after going through an automatic carwash, I noticed that the Oil Pressure is reading max on the gauge, 80PSI, and on the DIC, it is showing 128 to 130PSI steady. Also, recently I have run the battery dead due to leaving an aftermarket Satellite radio on accidently, that required a jump start. The car runs just fine, I've opened the oil filler cap, no oil spewed forth, no hissing, so I'm thinking its a bad sensor. My questions are these:
1. Is it okay to run the motor like this, assuming the idication is false?
2. What is involved to replace the sensor and/or gauge?
3. If replacement is needed, what have you seen as a ballpark cost with parts and labor to do the R&R?
4. Which is more likely the culprit, the carwash or the jumpstarts?
Thanks much,
John
Jan 29, 2007 at 1:41 AM
CARUNDELL
  • 602 POSTS
[quote:5f704e5a42="jgump"]I have a 1997 Chevy Corvette, with the LS1 V8, 5.66L, 345hp engine. It has 117,000 miles on it and has been well maintained. Two days ago, after going through an automatic carwash, I noticed that the Oil Pressure is reading max on the gauge, 80PSI, and on the DIC, it is showing 128 to 130PSI steady. Also, recently I have run the battery dead due to leaving an aftermarket Satellite radio on accidently, that required a jump start. The car runs just fine, I've opened the oil filler cap, no oil spewed forth, no hissing, so I'm thinking its a bad sensor. My questions are these:
Thanks much,
John[/quote:5f704e5a42]
Hey John
1. I recommend that we don't assume the sender is bad. Excess pressure can be as dangerous and lack of pressure.
Before any parts replacement I would recommend that you have a trusted shop perform a pressure test and get a good diagnosis of the issue, whether its the sender, the gauge or the oil pump pressure regulator, (which is a definite possibility!) Let us know!
Chris
Jan 29, 2007 at 3:21 AM
