1985 Chevrolet Corvette No Start
MARKMAC
i have a 1985 corvette i recently purchased for restoration.it has the 350 tpi system.the car wont start and i suspect the problem is in the fuel system.i have replaced the fuel pump and filter.i can get the car to start by pouring fuel in the intake but it goes dead again as soon as that runs out.the fuel pump wont run when i turn on the ignition.i can jump it out and make the pump run but the engine still wont start until i pour gas in the intake.i have checked and replaced all bad fuses in fuse block.ihave checked to make sure the fuel is coming into the fuel rails and it is.pressure should be ok from the pump because it and the filter are new.i also checked to make sure there were no trouble codes stored in the computer there were none.any help would be greatly appreciated :(
Aug 19, 2007 at 5:59 AM
2CARPRO JACK
  • 11,533 POSTS
As you know 85 was the first year for TPI, so they had some strange issues. You need to get a "noid" light so we can see if the injectors are getting pulse.All the fuel pressure in the world wont help if they arent letting it in.Check the fuel pump relay for power in and ground
Aug 20, 2007 at 1:03 AM
Suggested Repair
Use a noid light to confirm the injectors are receiving a pulse. Also check the fuel pump relay for power in and a good ground.
Conversation Summary
Owner of a 1985 Chevrolet Corvette with 350 TPI says it will not start. A new fuel pump and filter were installed, fuses were checked, fuel reaches the rails, and no codes are stored. The pump does not run with the key on unless jumped, and the engine only runs briefly after fuel is poured into the intake. The expert advises checking injector pulse with a noid light and verifying power and ground at the fuel pump relay.
