It sounds like the drainage system in your car is clogged with leaves or debris, forcing it to drain at a different location. You know the channels along the doors and the windshield cowel just below the windshield, well if leaves and other things are clogging it, rain and water will find another way to drain try to vacuum all of the leaves and debris from the doors and cowel and see what happens
SPONSORED LINKS
Friday, May 16th, 2008 AT 11:41 PM
