1989 Chevy Corsica Engine won't stay started
ARENAEUS
  • 1989 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 98,000 MILES
Last week the car started stopping at the end of the highway on-ramp. After replacing the fuel filter, fuel pump relay, plugs and wires as well as fixing a vaccum leak the car has gone from stopping on the road to shutting off immediately after starting. The coil is only six months old too so, we are running out of ideas about what could be the problem.
Wednesday, May 20th, 2009 AT 7:14 PM
  • 109,885 POSTS
Have you checked fuep pump pressure?
Wednesday, June 10th, 2009 AT 5:27 PM
ARENAEUS
Yes the pump is fine
Sunday, June 14th, 2009 AT 5:08 AM
  • 109,885 POSTS
If you have spark, good fuel pressure, and good compression, it should well. Does this have the 3.1L V6? If so, make sure there isn't a leak around the intake gasket. That is a common problem.
Sunday, June 14th, 2009 AT 4:22 PM
ARENAEUS
It's a 2.8L V6 engine
Wednesday, June 17th, 2009 AT 9:05 PM
