This car ran great for all of its time untill the day it stopped running while I was driving it. After it stopped running, every time id try to start it, it would run for about 1 minute, then die and wouldnt restart. One day I had it running for a 3 mile drive, and it ran okay. When you would lay into the throttle past 50% it would chug and sputter like it was running out of fuel. Finally got it home, and we have replaced the ECU, Fuel filter, MAP sensor, TPS, Crank position sensor, and done all kinds of tests. It does make 40psi of fuel pressure at the rail just on the turn of the key. Any ideas?
SPONSORED LINKS
Saturday, January 12th, 2008 AT 2:39 PM
