1989 Chevy Celebrity 1989 Chevrolet Celebrity Won't Start
CHEVYRIDING409
  • 1989 CHEVROLET CELEBRITY
  • 4 CYL
  • 275,000 MILES
I was driving down the road one day when my car just stopped. Now it wont start and I don't know what it is I have changed the coil packs and the starter. Every time I goto start the car there is a whining noise coming from the side the alternator is on. I had a mechanic look at it and he said something came loose in the base pan. And I don't know how to fix this problem
Sunday, August 23rd, 2009 AT 5:54 AM
Determine if its fuel or spark that's causing it-do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, August 23rd, 2009 AT 12:07 PM
