2002 cavalier 2.2 (96213 mi.)how do you replace fuelpump
Jul 10, 2007 at 3:26 PM
Support the vehicle safely, relieve fuel pressure, and lower the fuel tank with a floor jack and plywood after disconnecting the tank straps and fuel lines. Remove the pump from the sending unit, install the new pump, replace the fuel filter, reassemble in reverse, and prime the fuel system without starting the engine.
The owner of a 2002 Chevrolet Cavalier 2.2 asked how to replace the fuel pump. The reply recommended a repair manual and outlined lowering the tank after disconnecting the lines and straps, removing the pump from the sending unit, installing a new fuel filter, and priming the system before attempting to start the car.
