How much fuel will you lose when you change a fuel filter on a 1997 cavalier?
Aug 13, 2007 at 11:42 AM
Expect little fuel loss when replacing the filter. Remove the gas cap and wear eye protection. After installation, replace the cap, prime the fuel system three times by turning the key to accessory until the pump buzzes, then start the engine and inspect the filter area for leaks.
The owner asked how much fuel is lost when changing the fuel filter on a 1997 Chevrolet Cavalier. The expert said little fuel leaks and advised removing the gas cap, wearing eye protection, priming the pump three times after installation, then starting the car and checking the filter area for leaks.
