2000 Chevy Cavalier Speedometer Jumps
M19MIKE55
I have a 2000 chevy cavalier with the small 4 cylinder engine, 150,000 miles, 28-30mpg. Recently, while hiway driving, the speedometer jumps around like crazy. Sometimes this also involves a momentary loss of power. It seems to happen more frequently the farther I go e.g a 50 mile trip it may happen once or twice, a 200 mile trip it might happen 10-12 times. It only seems to happen over 50 mph.
Sep 18, 2007 at 5:30 AM
  • 75,988 POSTS
[quote:7b385c93d0="m19mike55"]I have a 2000 chevy cavalier with the small 4 cylinder engine, 150,000 miles, 28-30mpg. Recently, while hiway driving, the speedometer jumps around like crazy. Sometimes this also involves a momentary loss of power. It seems to happen more frequently the farther I go e.g a 50 mile trip it may happen once or twice, a 200 mile trip it might happen 10-12 times. It only seems to happen over 50 mph.[/quote:7b385c93d0]
Check your vehicle speed sensor could be loose connection. VSS tells the computer how fast the car is going could be the problem for both.
Sep 19, 2007 at 12:49 AM
Suggested Repair
Check the vehicle speed sensor and its wiring for a loose connection. A faulty VSS can cause both an erratic speedometer and momentary power loss.
Conversation Summary
A 2000 Chevrolet Cavalier with a 4-cylinder engine and 150,000 miles has a speedometer that jumps around during highway driving above 50 mph, sometimes with a brief loss of power. It happens more often on longer trips. The expert suggested checking the vehicle speed sensor and a possible loose connection, since the VSS tells the computer vehicle speed and could cause both symptoms.
