2004 Chevy Cavalier Window Motor Removal Fix
The first thing is remove the door trim panel, for this you need a tool to "pop" the plastic clips out after you have removed the screws, or you will break plastic anchor points inside the panel, after the panel is off, there are three screws and 2 rivets, roll the window 3/4 down position, remove the water barrier, or plastic sheet,remove the 4 nuts that hold the glass to the regulator, then push the glass all the way up and tape it there, use duct tape and just tape straight up the glass and over the top and down onto the glass on the other side. unplug the connector, remove the screws and rivets! To put new rivets in you need a two hand riveter!
Nov 2, 2007 at 8:17 AM
Suggested Repair
Remove the door trim panel screws and carefully pop the plastic clips so the anchors are not broken. With the window about three-quarters down, remove the water barrier, unbolt the glass from the regulator, raise the glass fully, and tape it in place. Unplug the connector, then remove the regulator screws and rivets; new rivets require a two-hand riveter.
Conversation Summary
The owner of a 2004 Chevrolet Cavalier with about 62,213 miles asked how to remove the power window motor and requested model-specific pictures. The expert explained removing the door trim panel without breaking clips, peeling back the water barrier, unbolting and taping the glass up, then unplugging the connector and removing the regulator screws and rivets, and shared reference images.
