My hood release latch cable broke. It is a 1992 Cavalier 4 cyl., with 127k miles. How can I open the hood to fix it
Apr 15, 2007 at 8:14 AM
If the cable broke at the handle, grip the remaining cable with pliers and pull it. If it broke under the hood, carefully use a flathead screwdriver to force the latch loose.
The owner of a 1992 Chevrolet Cavalier said the hood release cable broke under the hood and could not be pulled from the cabin. An expert first suggested pulling the cable with pliers if it broke at the handle, then advised using a flathead screwdriver to force the latch loose.
