1989 Chevrolet Cavalier Lukewarm Heater
DARMIL
I have a 89 caviler with 170,000km's.The problem I'm having is...the heater blows luke warm air.I've replaced the heater core, rad cause it needed to be,and thermo stat twice cause. I thought I bought a faulty thermo stat.
When you install the heater core if you mixed up the in and out coolant hoses. Will that make it blow luke warm.I'm not sure at the time if I mixed them up.Cause i can't figure it out,why it's not hot.Can anybody help?
Feb 22, 2007 at 3:02 PM
2CARPRO JACK
  • 11,533 POSTS
Need to be sure the hot/cold blend door is working properly.It is under the dash in the plenum assembly
Feb 23, 2007 at 12:17 AM
BHUGG
  • 157 POSTS
Another thought.
Is the A/C running at the same time. Look at the comperssor under the hood and see if the compressor is running. If it is, there is your problem.
Let us know. Get back to the forum.
If we help, let us know and give us a vote.
Feb 25, 2007 at 3:10 AM
DARMIL
My car doesn't have A/C so i don't think thats the problem.
Mar 4, 2007 at 1:20 AM
Suggested Repair
Confirm the hot/cold blend door under the dash in the plenum assembly is working properly. Air conditioning was ruled out because the car does not have A/C.
Conversation Summary
The owner of a 1989 Chevrolet Cavalier with about 170,000 km reports lukewarm heater air after replacing the heater core, radiator, and thermostat twice, and asks whether reversed heater-core hoses could cause it. Experts advise checking that the hot/cold blend door in the dash plenum works and whether the A/C compressor is running. The owner says the car has no A/C.
