1994 Chevy Cavalier Head Removal
No. The 3.1L has to have it completely removed to take the head off. The 2.2L has to have it disconnected and pulled away, so in both cases it needs to be removed.
I wouldnt. Which engine do you have?
The 3.1L would be like working on an engine stand, just have to bend over a little. You can rotate that engine over to get to the rear head if that is the one you are removing.
The 2.2L is right out there in the open. Just through you some fender covers on it and get to work. Should have the head off in about 2 hours.
Suggested Repair
Do not remove the engine. The intake must come off or be disconnected and pulled away before the head can be removed: fully remove it on the 3.1L, and disconnect and pull it away on the 2.2L. Leave the engine in the car; the 2.2L is accessible in place, and the 3.1L can be rotated to reach the rear head.
Conversation Summary
The owner of a 1994 Chevrolet Cavalier asked whether the cylinder head can be removed without taking off the intake manifold, and whether pulling the engine would be easier. The expert said no for both the 3.1L and 2.2L: the 3.1L intake must be completely removed, and the 2.2L intake must be disconnected and pulled away. The expert advised leaving the engine in the vehicle, noting the 2.2L is accessible in place and the 3.1L can be rotated to reach the rear head.
