2000 Chevrolet Cavalier Steering Wheel Removal Fix
PDWILKY
Chevy/Toyota Cavalier, 2000, 106000 4 cylinder.
How do I remove the steering wheel from my Toyota/Chevy Cavalier. I live in Japan and before I start into this task I would like to get guidance from a professional.
Thank you, Paul
Jul 18, 2007 at 9:41 PM
CLY
  • 308 POSTS
it should be pretty easy Paul....
First remove the negitive battery cable.
pull the 15 amp airbag fuse.
Remove the connector position assurance (CPA) from the driver yellow 2-way connector located at the base of the steering column.
use a T30 torx bit to remove the two screws that secure the airbag to the wheel.
tilt the airbag down and disconect the connector.Make sure and keep that retainer because it needs to be put back into place.
remove the horn wire by pushing down and turning counterclockwise 1/4 of a turn.
Then remove the steering wheel nut and install a steering wheel puller and remove the wheel.
Reverse these instuctions and reassemble....
thats all there is to it...
Cly
Jul 18, 2007 at 11:01 PM
PDWILKY
Cly, thank you, with your guidance was able to pull the wheel in about 5 mins.
Thank you!
Paul
[quote:342e39ae91="Cly"]it should be pretty easy Paul....
Cly[/quote:342e39ae91]
Jul 25, 2007 at 10:32 AM
Suggested Repair
Disconnect the negative battery cable and pull the 15-amp airbag fuse. Remove the connector position assurance from the yellow driver airbag connector, then remove the two T30 Torx airbag screws, disconnect the airbag and horn, and use a steering wheel puller after removing the nut. Reassemble in reverse order.
Conversation Summary
The owner of a 2000 Chevrolet Cavalier asked how to remove the steering wheel. The expert outlined battery and airbag fuse disconnection, airbag connector and fastener removal, horn disconnect, and use of a steering wheel puller. The owner reported the wheel came off in about five minutes using those steps.
