2000 Chevrolet Cavalier Engine Swap
CANNON68
I have a bad engine in my 2000 cavalier 2.2 engine I want to know if it will swap out with a 2002 cavalier 2.2 without having to change anything
May 29, 2007 at 3:57 PM
E40WATER12
  • 522 POSTS
Now is the motor in the 2002 cavalier 2.2 is OHV or the 140 hp eco tec motor, If its eco tec, Youre gonna need to get the wiring harnesses, Also need to re-weld the motor / Tranny mount brackets, Also change fuel lines and ECU computer, Also if its a 2.2 OHV motor non eco tec, Should be a straight swap over.
Good Luck.
May 29, 2007 at 9:28 PM
Suggested Repair
Confirm whether the 2002 2.2 is an OHV or Ecotec engine. A non-Ecotec OHV 2.2 should be a direct swap. An Ecotec requires the wiring harnesses, reworked engine and transmission mount brackets, fuel lines, and the ECU.
Conversation Summary
The owner of a 2000 Chevrolet Cavalier with a bad 2.2 engine asked whether a 2002 Cavalier 2.2 would swap in without other changes. The expert said an Ecotec engine would require wiring harnesses, re-welded mount brackets, fuel lines, and the ECU, while a non-Ecotec OHV 2.2 should swap directly.
