I have a bad engine in my 2000 cavalier 2.2 engine I want to know if it will swap out with a 2002 cavalier 2.2 without having to change anything
May 29, 2007 at 3:57 PM
Confirm whether the 2002 2.2 is an OHV or Ecotec engine. A non-Ecotec OHV 2.2 should be a direct swap. An Ecotec requires the wiring harnesses, reworked engine and transmission mount brackets, fuel lines, and the ECU.
The owner of a 2000 Chevrolet Cavalier with a bad 2.2 engine asked whether a 2002 Cavalier 2.2 would swap in without other changes. The expert said an Ecotec engine would require wiring harnesses, re-welded mount brackets, fuel lines, and the ECU, while a non-Ecotec OHV 2.2 should swap directly.
