1986 Chevrolet Cavalier Fan Won't Run
JOHN2005
  • 8 POSTS
I have a 1986 2.8 Chevrolet cavalier z24, 161321 miles. The cooling fan wont turn, it was working well before I change the radiator. Now my car will over heat. what can I do?[img:163e6a1b85]http://www.2carpros.com/forum/automotive_pictures/109106_chevroletcavalier11_2.jpg[/img:163e6a1b85]
Oct 22, 2007 at 8:07 AM
2CARPRO JACK
  • 11,533 POSTS
Probably have it mouinted wrong. Doublecheck how it is bolted in, must turn freely
Oct 22, 2007 at 8:10 AM
JOHN2005
  • 8 POSTS
ok thanks
and it the mouninted is ok.
can it be something something else
thanks
Oct 22, 2007 at 8:25 AM
2CARPRO JACK
  • 11,533 POSTS
Didnt have this problem til you changed out the radiator, look to see the difference between the two
Oct 22, 2007 at 10:07 AM
JOHN2005
  • 8 POSTS
ok ill give it a try
but when the car is off i pust the fan blades the blades will rotate, so is it still a mouinted problem
thanks
Oct 22, 2007 at 5:59 PM
2CARPRO JACK
  • 11,533 POSTS
There is the misunderstanding... you said now "the fan wont turn" which ususally means it is rubbing something.Did you miss any ground wires or was there a sensor in the radiator you might have forgotten to put in the new one? If you turn on the a/c does it come on?
Oct 23, 2007 at 12:52 AM
Suggested Repair
After the radiator replacement, confirm the fan is mounted so it can spin freely, compare the old and new radiators, and check for a missed ground or a fan temperature sensor that was not transferred. Also test whether the fan comes on when the A/C is turned on.
Conversation Summary
The owner of a 1986 Chevrolet Cavalier Z24 says the cooling fan stopped working and the engine overheats after a radiator replacement. The fan blades turn freely by hand. The expert first suspected incorrect mounting, then advised comparing the old and new radiators, checking for a missed ground or radiator sensor, and testing whether the fan runs with the A/C on.
