Chevrolet fan problem
JOHN2005
  • 8 POSTS
I have a 1986 2.8 Chevrolet cavalier z24, 161321 miles. The cooling fan wont turn, it was working well before I change the radiator. Now my car will over heat. and if all the mouints and bolted are not ther problem, what else can it be? what can I do?
Oct 22, 2007 at 9:07 AM
BLACKOP555
  • 10,386 POSTS
did you start with a manual clutch operated fan and switch to a electric fan?
Oct 22, 2007 at 2:36 PM
JOHN2005
  • 8 POSTS
i dont now when i bought the car the fan was already there and it was working, until i change the radiator. what is the difference of a manual cluth fan and electric fan? can you help me with my fan proplem? thanks
https://images.2carpros.com/forum/automotive_pictures/109106_chevroletcavalier11_1.jpg
Oct 22, 2007 at 5:39 PM
BLACKOP555
  • 10,386 POSTS
IS there a belt going around the fan that turns it or is it operated electronically by the battery?
Oct 23, 2007 at 1:56 AM
JOHN2005
  • 8 POSTS
there is no belt that turns the fan, so i think is operated electronically
Oct 23, 2007 at 10:11 AM
BLACKOP555
  • 10,386 POSTS
that narrows it down to a faulty fan switch or relay. or a bad coolant temp sending unit or coolant temp sensor. if those check out good the fan and make sure it is not bad.
Oct 23, 2007 at 3:00 PM
