1996 Chevrolet Cavalier No Start
EEWARD6583
My 1996 cavalier wouldn't start the other day. I turned the key in the ignition and there was nothing. No clicking, etc., just completely dead--car won't start, no lights, radio. No problems before this happened. I discovered I could tap on the battery posts with a wrench and then it would start. Now I go through this routine every time I want to start the car. Do I need a new battery? Alternator? Clean the cables? Not sure what to do and I certainly don't want to put much money into it and I'm trying to get a little more out of it before I get rid of it. Thank you!
Aug 9, 2006 at 1:06 AM
SYNCRAIT
  • 235 POSTS
i would try taking off the cables from the posts and using a wire brush just scrub them real good remove any build up or debris and reattach them nice and snug also check the grounding from the - (negative) to the frame and make sure that it is also secure and clean of debris....lemme know good luck :)
Aug 9, 2006 at 5:17 AM
Suggested Repair
Remove the battery cables, scrub the posts and terminals with a wire brush to remove buildup, and reattach them snugly. Also clean and secure the negative cable ground to the frame.
Conversation Summary
A 1996 Chevrolet Cavalier went completely dead with no lights, radio, or starter response, then started after the battery posts were tapped. The owner asked whether the battery, alternator, or cables were at fault. The expert recommended thoroughly cleaning the cable terminals and posts, tightening them, and checking that the negative ground to the frame is clean and secure.
