broken helicoil on spark plug
WSLICE3
what do i do when the helicoil that someone else installs breaks out? I have a '88 cavalier 135000miles, 4 cyl. (2.7L?) is there a larger helicoil or somthing else I can do... I do not want a very exspensive repair like a head replacement. Can you help please.. Thanks very much.
Bill
Jan 27, 2007 at 1:32 PM
CARUNDELL
  • 602 POSTS
[quote:ab9049efb7="wslice3"]what do i do when the helicoil that someone else installs breaks out? I have a '88 cavalier 135000miles, 4 cyl. (2.7L?) is there a larger helicoil or somthing else I can do... I do not want a very exspensive repair like a head replacement. Can you help please.. Thanks very much.
Bill[/quote:ab9049efb7]
Hey Bill,
If the threads made by the original heli-coil install are ok, then you can simply re-install another heli-coil. If not then the head needs to be removed and repaired/replaced.
Chris
Jan 29, 2007 at 5:45 AM
