98 Cavalier Fan speed control
MUSTANGMICKEY
Fan speed control...only works on 3 and 4 setting...1 and 2 do not work...not the switch, just replaced it. Is it a regulator or module? or what ever it is called...and where is it located so i can test it...or change it...Any help someone?
Jun 28, 2007 at 10:13 AM
E40WATER12
  • 522 POSTS
Hmmm, My friend just had fix that problem on his cavalier, I think its called heater fan transistor, Its located inside the heater fan.
Good Luck.
Jun 28, 2007 at 9:24 PM
BPRICE443
  • 66 POSTS
It is called fan speed resistor the power goes through different resistors depending on the posistion of the switch. I am not sure where it's located on your car but it is by the fan motor most of the time.
Good luck
brian
Jul 3, 2007 at 5:26 PM
