Electrical problem
2003 Chevy Cavalier 4 cyl Two Wheel Drive 93000 miles
cannot locTE THE WIPER BLADE MOTOR ON THE CAVLIER ONLY THE PASSENGER SIDE BALDE IS WORKING AND THE DRIVER IS NOT
Saturday, March 8th, 2008 AT 12:13 PM
MASTERTECHTIM
MECHANIC
They work on the same motor. Usually you can tighten the 13mm nut at the base of the wiper arm. The nut is covered by a plastic cap and you must pry it off to see the nut. Also check the other side because it is probably loose also.
