2003 Chevrolet Cavalier No Start
However i wouldn't jump to that conclusion. No compression, not fuel and or no spark have the same symptoms as yours is having. Like a light bulb, it can flicker before it goes or or it just goes out.
Just yesterday we had one that started out like yours, but when we got it, it barley cranked. The first thing was to get it cranking, battery went bad. Then it cranked and started. After a few tries, we were able to experience the no start. We couldn't hear the fuel pump run. Turns out the connector to the pump pump was corrodeed.
If that was your original fuel filter, then I wouldn't be surprized if the pump has been compromised.
Suggested Repair
Diagnose the no-start only while it is occurring. Check for fuel, spark, and compression, and inspect the fuel pump, its connector for corrosion, and the fuel filter. An intermittent failing component or wiring issue is most likely.
Conversation Summary
A 2003 Chevrolet Cavalier with about 60,000 miles suddenly cranked but would not fire after running normally earlier that day. Battery and oil checked fine, and lack of fuel was suspected. The expert said a fuel pump can fail suddenly, but no fuel, no spark, or no compression can cause the same symptom. After towing, the car started and shop tests found nothing. The expert explained that intermittent faults are hard to diagnose unless present, citing a corroded fuel-pump connector as an example, and noted that an original fuel filter could have compromised the pump.
