High beam headlights not working
DSANDERS1111
Yeah, I agree that it is the wiring. I appreciate your time and consideration. Thanks!
Thursday, February 22nd, 2018 AT 1:06 PM (Merged)
KEVINMART
  • 2003 CHEVROLET CAVALIER
  • 4 CYL
  • 42,000 MILES
Electrical problem
2003 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 42000 miles
I replaced both headlights on my car. The high beams work the low beams don't. Why?
JDL
  • 16,098 POSTS
The ground circuit controls on and off, also bright and dim. There might be a problem with the low beam circuit to the dimmer or a problem with the dimmer.
DESOSHADE
I have the same problem. Fuses are all fine. Daytime running lights work, high works, no low. So I either drive with my highbeams on and blind everyone (and get pulled over) or turn on only my parking lights and use the DTRL, but that's not enough light to see.
CLARK317
  • 2001 CHEVROLET CAVALIER
  • 98,000 MILES
My calivers pass. Side headlamp is not working. The runing lights work but the auctly light does nt come on and when I turn the brighs on it shows a wrench light on the dash then it goes of. Ive put a new bulb in and it still doesnt work
SATURNTECH9
  • 30,869 POSTS
Have you checked the fuses?Also do you have a multimeter to do some testing?
