Engine Mechanical problem
1997 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 188000 kilometers
OK here goes... about a month ago my car started leaking fuel around injector 1. So i replaced the o rings on all injectors and then it stoped leaking. in the meantime it would occasionally backfire, i assume thats from the leaking injector. Worked for a while, then it started running on 3 cylinders.. thought it was the bad injector again, but i did a compression test and cylinder 3 only had 30 PSI of compression... so i continued to drive it and it was working ok as long as you maintained steady speed. Then when i was driving it out to school, it quit!! dead!. I towed it to my school and put it on the hoist. Compression test again and all was good 165 in all 4 cylinders. Tested injector drivers with noid lights and all seem to be working. Checked for cranking vacuum, and got Nothing! should be 10 inHG min. hmmm so, car wont start, and i think its because it has no vacuum, but not sure how to check for the location of the vacuum leak. Just a guess but i think that the vacuum leak is in the vicinity of the intake manifold as it was backfiring, into the intake i assume, and blew the gasket. But not Positive. Where else can i check for leak in vacuum. any help will be greatly appreciated. THanks
Mar 4, 2008 at 11:21 AM
