1997 Chevy Cavalier car won't start
SUNSHYNE1576
  • 1997 CHEVROLET CAVALIER
Engine Mechanical problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
I have borrowed a car from a friend. It had sat for a while before I started driving it. It drove very rough. Hesitating up hills and low acceleration. I drove the car to work tried to start it at lunch. It won't start. It tries to start but definatley won't. Thought it was the coil packs and changed the whole assembly. There is fuel to the rail not sure if it is sufficent. I don't have access to a computer so I don't know if it is throwing codes. I am going to try to change the crank sensor and ignition sensor just to see if that changes anything. Oh and I am getting spark. Any suggestions?
Wednesday, September 29th, 2010 AT 6:39 AM
You're getting fuel, now you need to check if the fuel pump is producing the correct fuel pressure and the injectors are pulsing.
Wednesday, September 29th, 2010 AT 6:48 AM
NICKHEADZ34
  • 62 POSTS
Fuel pump may not be hitting the lbs. You need. And it would crawl only get to about 20mph and would really only run smooth at idle. I had this happen before with my luminaz34. Crawled to work and then it wouldn't start. Turned out to be a half dead fuel pump
Saturday, October 2nd, 2010 AT 5:56 PM
SUNSHYNE1576
I had the fuel pump changed. Cranking is a little better stiill won't start. If I hold my foot on the throttle it chugs like it want to start just won't. I did get a tps code. Could the tps stop it from starting?
Friday, October 8th, 2010 AT 7:31 AM
Do you have spark and also did you check the fuel pressure after the fuel pump replacement and also check if the injectors are pulsing providing fuel into the cylinders. If not check it
Friday, October 8th, 2010 AT 1:54 PM
Related Engine Not Running Content
