1997 Chevy Cavalier Turn lights
DAVID PRICE
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • 60,000 MILES
The turn lights have stopped working. Is this just a fuse? How Can I fix?
Friday, April 2nd, 2010 AT 11:21 AM
TWOSTEPPER
  • 42 POSTS
There is a turn fuse in the fuse box. Use a voltage tester and check voltage at fuse circuit, goes hot when you turn on the key. Do the lower brake lites work? In the rear, the lower brake lite and turn work on the same bulb filament, just not at the same time.
Friday, April 2nd, 2010 AT 11:53 AM
