REALTORJOHNC
I have a 1994 Chevrolet Cavalier. 2 door 4 cyl. 190000 miles.The turn signals will not flash when pulled on. The emergency flashers work. I have installed all new bulbs. I replaced the flasher in the fuse block under the left side of the dash.When I remove the flasher while the emergency flashers are on they stop blinking. I understand there may be another flasher somewhere on the car. My question is does the car have a separate flasher for the turn signals and the emergency flashers.
Nov 15, 2007 at 1:50 PM
  • 75,988 POSTS
Behind dash on right side of steering column support
Nov 15, 2007 at 2:05 PM
