1990 cavalier stalling at a stop
ZB12691
i have a 1990 cavalier z24 with 200640 miles on it. its got a lot. when i go to stop the rpms drop and bounce untill the car stops moving or i give it gas. it does it around turns too when im slowing down. i would donate more but its all i had on paypal. ill give more when i put more on.
May 13, 2007 at 9:33 AM
2CARPRO JACK
  • 11,533 POSTS
Has it been tuned up? remember to use OEM parts, cheap tune up parts are exactly that- cheap parts. Remove the air intake tube and clean around the throttle plate inside the throttle body with some carb cleaner.
May 14, 2007 at 1:13 AM
ZB12691
it works fine when the AC is on. ok ill try that. thanks!
May 14, 2007 at 6:52 AM
