Hello my car will crank fine under 18-20 degrees but will not start it will pop run rough and die after long crank if it trys to start at all above this temp it will start fine and runs fine it does seem like it cranks a little longer than normal. It has new plugs wires coil air charge temp sensor and fuel pump. Can u help?
SPONSORED LINKS
Wednesday, December 30th, 2009 AT 8:33 PM
