Do you have an engine light on? If not could be several things. I would start by check ing fuel pressure and spark, then we can take it from there. Engine coolant temp sensor can cause that problem, but it will usually cause an engine light if something is wrong with the ect. Also the crank position sensor will do the same, but it will cause the vehicle to shut down while driving. So just check the first to things that I asked you to and get back to me please with your findings, I will send you a couple of video links to show you how in case you dont.
SPONSORED LINKS
Monday, April 27th, 2009 AT 9:56 AM
